Hallo, Besucher der Thread wurde 518 aufgerufen und enthält 0 Antworten
letzter Beitrag von mipu am 4. Mai 2024 um 09:06
  • The Sims™ 3
    The Sims™ 3
    Info
    Entwickler
    • The Sims Studio
    Genres
    • Simulationen
    Plattformen
    • Windows
    Metacritic
    86
    Beschreibung
    Get the Latest Version of the Sims
    https://store.steampowered.com/app/1222670/The_Sims_4/
    Über das Spiel
    Play with Life.
    Create the lives you've always wanted!
    Ready to live a freer, more creative life? In The Sims™ 3, you can let your fantasies run wild as you design your ideal world. Start with your Sim, refining each shape, color and personality trait until you get the precise person that pleases you. Design your dream home, but don’t let a grid limit you; place, rotate and stack furniture and walls freely and to your heart’s content.
    Once the “hard work” is over, it’s time to be a mentor. Guide your Sim’s path through life, developing a career, finding love, and pursuing dreams and desires. Spending time with friends and family is just as important as mastering painting or accumulating knowledge.
    Take things to the next level and record movies of your Sim’s adventures and share them with the ever-growing and thriving community. With a huge catalog of expansion packs and fun objects to discover, there is no end to the possibilities awaiting you. It all begins here; your adventure awaits!
    Key Features
    • Customize Your Sim: Mix and match a vast range of facial features and body types to get the look you want. Infuse your Sim with personality traits and help realize their dreams.
    • Stage Your Own Extreme Makeover: Decorate your Sim’s home however you want, neat or messy. Use odd angles, create tall stacks of items, and apply your favorite self-made pattern to the walls and floors.
    • Range From the Home: Get out of the house and explore the lively and entertaining neighborhood for the first time. Be a part of the larger online community!
    Screenshots
    Website
    http://www.thesims3.com/
    The Sims™ 3
    This product uses the steam API.
    ThreadStarter by noexcept.de
    Test
    Hallo,gefällt dir der Thread, willst du was dazu schreiben, dann melde dich bitte an. Hast du noch kein Benutzerkonto, dann bitte registriere dich, nach der Freischaltung kannst du das Forum uneingeschränkt nutzen.
